Installation of a Greddy elbow - what pipe to use???
Started by Tiger_kpt, March 29, 2007, 10:00:54 AM
Tiger_kpt
As above really. I have a Greddy elbow with BOV flange and Greddy Type RS BOV kit to match. I know how to fit these, not a problem.
One thing I am stuck on though which I could do with a point in the right direction is - what pipe to use to make the connection between the Greddy elbow and the intercooler. What material. What particular pipe do any of you recommend? How much is it? And where do you get it from? Am after one quick.
Thanks guys. :cheers
probedb
If you still have the factory plastic elbow from the intercooler top then you\'d need a connector pipe between it and the elbow, same if you have hard pipes as well.
I think you can get away with normal Samco type hose. They also do turbocharger hose which is stronger :)
Tiger_kpt
Are there no easily purchasable kits containing everything that you need suitable for the Greddy installation on the FD RX7? Containing a metal pipe and the fittings? There\'s got to be.
interloper393
you can buy a full greddy elbow + pipe kit, its around 200 notes tho, 250 with 2 injector slots, in the kit you get the elbow, plus all hard pipes for the standard intercooler.. only kit iv seen bud
Tiger_kpt
Where is this kit for sale mate? Any links or contacts?
brundish24
newera parts up the top have it and the pipes on there own aswell i think
