Howling Turbos - sounds like a blues singer!
Started by merlyn, February 06, 2007, 01:30:34 PM
merlyn
Can anyone help
just changed the old induction to apexi\'s and hand pipes all the way - what a difference!
BUT
the turbos howl at cruising - not foot down when they whine and breath just fine but am worried might damage them in the long run (and force me to go single!)
Pete
merlyn
CraigN
whats the "howling like"
normal suction type noise or "screeching type" I had a T3 turbo once that made a horrendous noise, turned out it had screwed bearings and the shaft had become unbalance leading to compressors touching ths housing. Thus causing the awful noise.
skybusr34
i had a vw passat 20v turbo 1.8 petrol , turbo howlwd on that. turned out the oil pump was on its way out and wasn`t pumping oil to turbo. fried bearings
merlyn
none of this sounds very promising ... but thanks for the info
the howling sounds like someone blowing over a very large, and loud, bottle - there is no grinding to it and directly you spool up the turbo properly everyone sound sweet - no screetching or anything. i haven\'t touched the turbos themselves and thought it might just be the hardpipes but then again I can hear the turbos better so presumaby i would be able to here any problems beter too.
any ideas as to how i can work out whats wrong - other than taking the whole funking thing apart that is.
ro284
merlyn
Quote from: ro284Merlyn could it be the air pump mooing?
Bob
don\'t know - didn\'t notice it before the hardpipes
only happens at boosts of minus 0.2 to plus 0.2 bar - i thought it might be the wastegate
ro284
A quick test would be to unplug the air pump and drive the car. at least that would eliminate that possibility, whaen i fitted Apexi intake, i found it was the air pump mooing because it\'s not connected to the filter box,
Bob
merlyn
Quote from: ro284A quick test would be to unplug the air pump and drive the car. at least that would eliminate that possibility, whaen i fitted Apexi intake, i found it was the air pump mooing because it\'s not connected to the filter box,
Bob
Thanks - will try that at the weekend
yamaster
Quote from: merlynThanks - will try that at the weekend
sounds like the air pump noise. drive it slowly in first and rev it up at aroud 2500rpm it sound shut off.
i thought the same when i fitted my filters
merlyn
Quote from: yamastersounds like the air pump noise. drive it slowly in first and rev it up at aroud 2500rpm it sound shut off.
that\'s exactly what happens - thanks guys
i guess to cure it i will just have to decat and remove the air pump
never mind eh?
cheers
