boost problem
Started by rx7eaven, February 05, 2007, 03:30:46 PM
rx7eaven
Hi everyone.
I have an interesting problem. Under WOT and at full boost the pressure is not regulated properly, it reachs around 14 psi in first and second turbo but fluctuates slightly, you can hear this when driving and i can also see this on my pfc (6 month old). (you can see small peaks and dips on the graph).
I have tried removing the conectors on the turbo pre-control and wastegate solenids and the boost pressure reachs 7psi and is maintained perfectly, (there is no fluctuation at all). Does anyone no if this proves the wastegate is working properly?
I have tried replacing the wastegate and turbo pre-control solenoids and the problem still remains. Since the boost is regulated at around 14 psi when the solenoids are pluged in im asuming the problem could be with sensing the pressure or an electrical fault.
Can anyone shed any light on these problems?
My car is a uk model rx7
recently rebuilt engine
new turbos
pfc
hks super drager exhaust
hks induction kit
hks boost pipes
Thanks for your help guys. :Thumbs-up
rx7eaven
hello again. I have solved my own problem, wel with a little help from clive! He advised that i try my old ecu and the problem disapeared! so im gona try and get it re-mapped.
Can anyone recomend someone near gravesend in kent who will re-map the pfc. thanks.
