Top rear brake light replacement
Started by Gatesy, February 28, 2009, 10:12:20 AM
Gatesy
Guys I\'ve searched on here but not come up with any results.  One of the little brake lights at the top of the boot has gone and needs replacing.  What do I need to replace it with?  Bulb or LED?
Ada7
Should just be a bulb. I think you have to remove one if not both of the side light clusters to be able to get the centre section off. The you\'ll see the 3 bulb holders on its back
Adam
I AM HERCULESIAN
Nik da Greek
Pretty sure they\'re just a standard capless 501 sidelight style bulb like these;
http://cgi.ebay.co.uk/NEW-x-10-OSRAM-SIDELIGHT-AUTO-BULBS-501-12V-5W-W2-1_W0QQitemZ250373891861QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item250373891861&_trksid=p3286.c0.m14&_trkparms=72%3A1683|66%3A2|65%3A12|39%3A1|240%3A1318
Like Adam says, take off the two main rear light clusters and then it\'s easy enough to undo the four (I think) nuts that hold the center brakelight unit on. They\'re hidden by a black placcy trim that just clips out
Ada7
I\'ve got a spare middle section for sale if you want to swap the whole thing :p
Adam
I AM HERCULESIAN
Eddie
Hi m* interested in the spare middle section how much delivered to Oldham please.
Gatesy
Cheers for the info guys.  This is the least of my worries with the way my FD is turning into a swimming pool at the moment so it\'ll have to stay broke for the time being but at least I can get the bulbs so I can have a go one sunny saturday when the missus is in work.
Ada7
Quote from: Eddie;587921Hi m* interested in the spare middle section how much delivered to Oldham please.
How does £40 delivered to your door sound? :D
i\'m not sure if they are any different but its from a 99 spec set of rear lights
Adam
I AM HERCULESIAN
Eddie
Hi ada7
its too expensive for what i want, im only going to be getting the heat gun out and splitting it to fit leds.
Thanks for the offer anyway.
regards
