turbo translation
Started by Mr_7, December 09, 2006, 04:06:46 PM
Mr_7
Decided to go single after reading many threads i want a T04 size turbo which keeps drivabilty, with low spool but enough effeciecntcy to get big power eg 350- 380rwhp at the upper rev range, what can i expect from this following turbo on an apexi, decat, mild street port any help thanx
- GT45 T4
- Inlet (Exducer/Hot Side) T-4 Flange 70.1mm x 82.55mm (2.76" x3.25").
- A/R 1.05 Exducer
- A/R 0.66 Compressor
- Cooling/Lubrication Oil
- Outlet (exducer/hot side) 4.25" V-Band
- Inlet (compressor/cold side) Ø 109mm (4.25")
- Outlet (compressor/cold side) Ø 86mm (3.38")
- Compressor major diameter Ø 98 mm
Mr_7
Shyne
BIG SNAIL!!!!!! have you spec\'d any of the supporting mods? Fuel, I/C, MAP sensor etc
The 45 is more than capable of supplying boost, its all about tuning for real power figures fella.
Best of luck though, I like the idea of a 45 on an FD!!! Yum Yum
sadgoth
You might find it somewhat laggy if you have a mild streetport though. The big Garrett turbos (most of which are really truck turbos) need a lot of flow to spool up, big ports will happily run big tubbys
Mark
89 Black FC3S Turbo II
Loud? Hell yes! :D
Shyne
That said, the GT\'s do have the slight benefit of ball Bearings so BAT is going to be lower than the equivalent bushing turbo.
antnicuk
i think that would be quite laggy as mentioned
i have a gt35/40 which creates 380 rwhp on a Turbo II engine so would give more on an FD. I get full boost at about 3600 ish rpm.
Mr_7
cheers guys il look around and have to deciede soon as a single is screaming out to me lol
Mr_7
im probably going to spec it as the follows:
GT 45 turbo
600*250*65 FMIC
044 fuel pump
Injectors (not sure need help on selecting)
Apexi Comander
3 bar map sensor
Not sure of other parts as il check as i go along last car i done was my 3DR RS500 it made 380rwhp so need MORE
imebgo
I think I have found this turbo on ebay,
Is that what your going for still?  How are you going about sourcing the rest of the stuff? manifolds etc..?
I was looking at a complete kit but im edging towards seperates from ebay and various sources.
J
Ed_RX7
#9
looks like a chinese piece of (xs power) crap if you ask me.......but if thats what you want then go for it.........(seems far too cheap)...you do get what you pay for!!!!!
http://cgi.ebay.co.uk/SKYLINE-RB26-GT45-Turbo-Manifold-and-50mm-WG-KIT_W0QQitemZ250071146558QQihZ015QQcategoryZ38786QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Edrx7Parts
07531 669 768
Also of
