Removing carpet!
Started by jetpilot, January 02, 2007, 04:11:34 PM
jetpilot
Is this a tricky job guys, or relatively easy?
K1HKS arse
Relatively easy except where carpet goes over transmission tunnel behind dash.Carpet is fitted before dash so you either have to loosen dash where it bolts to tunnel(still tricky getting carpet out) or you cut carpet along tunnel behind dash and remove alot easier.Make sure cut is as close to middle of tunnel as possible so cut is hidden when it goes back in.
If you require another interior carpet i have a good one for sale.
jetpilot
Thanks Gary, will be in touch if i get a little too happy with the stanley knife!!
