Primary Fuel Injectors, Clean?? Recon?? Replace??
Started by chrisJDM, December 18, 2006, 09:26:36 PM
chrisJDM
Just ordered:
1600cc Secondary Injectors
Nippondenso Fuel Pump
Competition Fuel Rail
So im upgrading the lot apart from the primary injectors, i know i dont need to upgrade them but odvioulsy they are getting quite old now so prob arent runnig at 100%, so should i get them changed?? or can anyone recommend a good injector cleaner? or how much is it to get them reconditioned???
G@NDY
Just get them cleaned. I think i read that Pip does it about £15 each, but i could have just made that up:2Confused
edit; http://www.wgtautodevelopments.co.uk/
It doesnt go to the right bit when you click that. But on his page there is a bit about injector cleaning
John Yorke
REworx have a machine that cleans and will match up the flow rate for you, mind you will have to wait till after Xmas as they are on holiday now, I do believe they do a postal service as well, if you are not in a hurry it might be worth the call:cheers
chrisJDM
any idea how much it costs for reworx to put them in there machine???
Jit
chrisJDM
not bad sounds good, although i have to say a mate of mine sent his away a while back and they took ages to do it and he wasant impressed wit the service, not that i wanna start a slagging thread or anything just thats wot he said at the time.
