nice item, group buy on RX7club, look!
Started by Bobfish, December 10, 2006, 05:05:29 PM
Bobfish
Saw this, i think its a really nice item. Has an internal oil baffle to stop the oil going where it shouldnt, looks nice and is really quite cheap at $117 for a polished one - gives some nice bling to your engine bay :)
http://www.rx7club.com/showthread.php?t=603089&page=2&pp=15
Sign up guys ;)
Hayward North
Ah sore this when it was pre production, kinda nice if you dont want oil to make its way to your combustion process.
If i rember rightly its baffeld inside so oil cant creap up the neck on hard cornering so eliminating the need for a catch can.
Regards
Steve Garbutt
Hayward Rotary North
probedb
I\'ve put me name down...I\'m killswitch over there :)
Bobfish you need to reply and confirm you\'re still interested as they\'re only marking the initial replies down as interested if you confirm now!
RemarkLima
Can someone breifly explain the oil system on rotary please?
I\'m a bit confused, but guessing that effectively what would normally be crankcase pressure breathed back into the airbox (along with oil mist etc) is now just being pressurised into the sump... Which is then breathed backup the filler neck which has a breather into the air system somewhere?
So with a baffle in the filler neck it\'ll mean that pressure can escape but oil and oil mist can\'t so easily???
