Greddy profec b2 question
Started by stylus350, November 03, 2006, 10:18:44 AM
stylus350
Hi.
I have one of these in my FD but no instuctions. When I turn on the ignition it does a couple of things on the display resulting in it saying \'OFF\' just before going into its normal state of showing boost (at least thats what I think its showing!!) Does this mean its not doing anything? Any one with instructions willing to give a brief outline of functions and how to adjust them? :)
You can downdload the PDF\'s for these from the greddy website :
http://www.greddy.com/img/PHP/products/pdf/682.pdf
stylus350
Quote from: ProfYou can downdload the PDF\'s for these from the greddy website :
Brill! Thanks :Thumbs-up
nikp
Just out of interest, where is yours mounted? I trying to decide what to do with mine!
antnicuk
you have to switch it on by holding the top button down for 2 seconds,  while its off boost if set to normal wastegate pressure.
Make sure when you switch it on boost isnt set to a stupid level
stylus350
Quote from: nikpJust out of interest, where is yours mounted? I trying to decide what to do with mine!
Its behind the steering wheel on top of the plastic cowling in front of the clocks. Held on with velcro and looks very at home there.:)
stylus350
Quote from: antnicukMake sure when you switch it on boost isnt set to a stupid level
Was thinking the same thing!. Will check it before I go anywhere. Thanks.
nikp
Cool - that\'s where i was thinking of putting mine. How are the cables routed? Are there any holes drilled in the cowling, or do they slip down behind it?
jonrx7uk
Mine\'s on top of column too.  I had to heat a screwdriver and melt a semi circle in the edge of the plastic cowl for the vac pipe to go under the instrument cluster (only slightly).  This stopped the vac pipe from pinching.  Best place for it though, just dont put your hand through the steering wheel when using it!
Jon
nikp
Another thank you to you my good sir!
jonrx7uk
No probs, if i could post a pic i would!
Jon
