wheel alignment q\'s.
Started by D1 WTF, October 31, 2006, 11:06:31 PM
D1 WTF
i know there is the sticky at the top.  but what do i want to set mine to.
my rex is on 18\'s F 235/ R 265
on tein HA coilovers.  isn\'t silly low, but obviously a lot lower than stock.
it is my only car so is used as my daily driver.  do i want to just put it to the street settings in the sticky?  are these settings same as stock FD?
RAW
i went for long track with similar sized wheels to you. couldn\'t quite achieve it as my car is too low but close enough.
Quote from: D1 WTFi know there is the sticky at the top.  but what do i want to set mine to.
Any good company that offers laser line or similar 4 wheel geometry checks / adjust meant will have the spec in the database to enable your suspension to be adjusted correctly,
I have always believed this is one of the very best things you can do to these cars to ensure they drive correctly and it saves you money because you take away the risk of scrubbing your tyres out.
Have a check done on all the suspension bushes first or you could waste money because they are unable to adjust the suspension accurately
though  or you will waste your money
Frankie
Quote from: RAWi went for long track with similar sized wheels to you. couldn\'t quite achieve it as my car is too low but close enough.
Same here went for close to the long track settings.  Had way too much negative camber before getting it done, car was twitchy. Now feels well planted and doesn\'t eat tyres. Running on 8.5 x 17 235/40\'s front and 9.5 x 17 255/40\'s rear.
