Apexi Fitting Help
Started by allstaruk, October 25, 2006, 05:52:11 PM
allstaruk
Hi ya guys,
I\'ve just got a second hand apexi power FC it came from a single turbo, now its going into my at the moment stock twin turbo so will obviously need to be set back to the base map, also will it need to go through any kind of set up process, basically what I want to know is how do I get this all up and running.
Alan
kermit
Once you physicaly fit it, you need to reset the PFC and do the learning process.  Follow this link and read the instruction manuals.  Its easy to reset and do the learning process again.
http://www.mazdarotaryclub.com/forums/showthread.php?t=5579&highlight=apexi+manuals
Martin
allstaruk
Thanks mate,
I take it as I am putting a decat on I can just unplug the Lambda sensor and poke the wire back inside the car?
Al
kermit
Yeah thats all I did with mine.
nikp
Not lambda sensor, heat sensor. but i suspect you just got your wording wrong, not the actual sensor! :D
allstaruk
The one on the CAT, thinking about it it probably is the heat sensor, well can I just unplug it?
Al
nikp
I think that\'ll throw an error on it. That\'s why a lot of people leave it plugged in - the ECU is expecting it to be there. Although, that might be the standard ECU. Now I\'m not sure!!
allstaruk
We\'ll find out in a min, its not like the apexi uses the heat light for what it supposed, to.
Just finished taking the cat out and its not spiting flames
allstaruk
Just fitted the power FC, reset it an started the car to start the learning process and the heat lighti it permenantly on, i got the sensor from the cat I removed unplugged.
Having never had a power FC I have no idea what to do, any one got any suggestions
Alan
allstaruk
Sorted not to worry ladies and gents.
Thanks for your help guys
Alan
SupraZed
Hi, how was it sorted, just interested for future reference.
TIA.
allstaruk
It was sorted by reomoving the heat sensor from the car taking the drivers seat out plugging it and a taping it out the way, it seems the sendor isn\'t used but is has the be there.
Al
MAZDASPEEDTIM
In a lot of vehicles the cat temp sensor wire (single wire sensor) can be cut and connected to earth (just connect to the body somewhere) to turn the light off.  If it is a two wire sensor bridge the two wires.
