My Shiney Engine is Back together
Started by deanflowers, October 03, 2006, 10:08:32 AM
Bobfish
The injector connectors are ALL Grey. NOT GREEN!
There should be 2 or 3 green connectors under there. One green one goes to your fuel temp sensor, its the one that sticks out of the secondary fuel rail. The other green connector goes to your coolant temp sensor, it the back of the water pump housing.
see fuel temp sensor here-its the green one by the ACV. You can see half of it there, its not connected
See other green connector here...its the one under the hose on the left of the pic, plugging in <--- that way into the water pump housing. You can also see the secondary injector plug here, its just under the bottom left stud that attatches the LIM to the UIM,  its the grey one.
deanflowers
That makes sense, i had no idea what the one of the coolant sensors looked like as it had been smashed clean off. so i think its all right, which is a slight relief, still got to take the inlet manifold off to put in place one part i forgot not sure whether to cable tie the ends of all the vac hoses though, some people do and some dont.
Bobfish
Ive never bothered and never had any problems. Depends what diameter hose your using though, if it fits tight or not.
