what size of water adapter plate
Started by mikeyh, October 10, 2006, 08:51:50 PM
mikeyh
do i need
im putting in other gauges and unsure of what size water adapter pipe i need to use?
thanks
mike
mikeyh
come on guys some one must know the size and what pipe it goes onto?
Nitronige
hey, will have to look for the reciept, got it from burton power. think it is around 40mm. i assume its the one for the rad hose.
FD3S Black - Yay!, Classic Mini turbo Black - Yay!, Dutton Pheaton - Lambo Green - Yay! Nissan Stagea (SOLD) Silver - Yay! Daily runner, Renault Clio 1.5dci - Booooo Hissss
mikeyh
dont know where these go as theres a choice of sizes.
also need to catch up with you m8 give u the cash i owe you
Nitronige
i was just thinking, im not using mine, i have the sensor plumbed in to the filler neck now, after fitting the v mount.
the sensor had a 1/8 thread. i had the adaptor on the top hose of the rad, but the guage only started to read when the thermostat opened.
nige
mikeyh
cheers anyway
so anyone esle help me out so i can get these parts orded please.
Quote from: mikeyhdo i need
thanks
mike
Sorry for the late reply, only just seen this
You can either put the sendor in the top water hose ( 38mm i.d.) or as has been said, use one of the allen key bungs in the thermostat housing
mikeyh
oo never thought of using one of them
ok ordering time and even more cash lol
does this ever end?????????lololol
Frankie
Mikey I am gonna to be installing my water temp gauge this Friday (as well as oil temp and oil pressure gauges). I\'m going to install the sender in the thermostat housing by removing the allen bung by the coolant cap. Will let you know how i get on!
If you can find a t-piece with a 1/8npt adapter small enough you could place the sender in the throttle body hose (i think the hose is just 12mm). I couldn\'t find one anywhere in diy or plumbing places. As Clive advised the rad top hose is easy enough.
mikeyh
yeah think ill just put it in there(rad cap)
cheers guys
