Heat light flicker help
Started by Travis, February 02, 2007, 10:14:35 PM
Travis
I know theres a few posts out but just wondered if anyone had an idea about my problem,basically about 2 weeks ago when i was quite low on juice i saw the red heatlight flicker 3 times,at the time i was driving at about 30 on low revs off boost,i filled up with juice and it was ok.Today on the way back from work,it done it again i had a quater of a tank so filled up and it kept doing it,it happend about 3 times on my way home,strange thing is it was doing it when off boost with no revs on aproaching junctions etc,on full boost i get about 60% at 1 bar injector duty on the commander and all the temps were good,its got a full decat.i will take it out tommorow to see if it still does it and i will keep an eye on the knock values on the commander,as iv just found out you can do this.Any ideas?
                                       cheers
Travis
ohh yea and does the apexi store high knock?if so how do i see it?or do you have to watch it whilst driving?
                                              cheers folks
Kash_
it could be a dodgy knock sensor? to view the highest knock reading press the up arrow on the Apexi Commander
