sequential turbo set-up
Started by japjim, October 04, 2006, 08:24:07 PM
japjim
can anybody tel me if both turbos set up to run sequential should be reaching the same boost levels.
according to my pfc commnder on a run today was showing that the first turbo is peaking at +0.80 kg/cm2 and the second is only reaching +0.59 kg/cm2.
any help would be good. bearing in mind that i am not very technically minded when it comes to things like this which isnt really that clever when you own a rex.
james
im guessing it could be a leak from somewhere
Ricco_04
I believe pre 99 spec should read 10-8-10psi and 99+ spec should read 12-10-12psi.
Mine (1995) hits 0.8bar
HTH :)
japjim
yeah mine is 95 on an m plate sorry what do you mean by 10-8-10 psi
Ricco_04
10 psi is the boost it\'s set to run at from the factory - on transition of 2nd turbo it should dip just for a split second to 8psi and back to 10psi.
