Delimiter / speedo converter???
Started by Jono FD3, September 27, 2006, 01:18:56 PM
Jono FD3
A mate has just bought a Rex and needs a delimiter / speedo converter chip...... Can anyone tell me where he can get one???? and roughly what price??
Cheers guys n gals
Jono
JiM B
Jimmys Mazda RX-7 specialist supply a converter / de-limiter. It was fitted to my car and i\'ve had no problems with it.
http://www.jimmys-rx7.co.uk/LinksandContacts.htm
strange_days_uk
I have one you can have for £15 delivered.
Otherwise, a guy sells them on ebay for all the jap cars, and he is very good.  They go for about £40 I think.
Zee
I\'ll take this for £15 if it\'s available?
Obviously 2nd dibs with Jono having the first ;)
strange_days_uk
Hi Zee,
Jono has the dibs and will be coming back to me soon.  If he decides against it I will PM you as second dibber !
Zee
Quote from: strange_days_ukHi Zee,
Yep mate, that\'s grand :)
kev-yorks
Your better going for the variable type de-limiter the fixed rate ones just convert from kph to mph go for a variable one and you can alter the settings to suit wheel tyre combinations when you swap them from stock. heres a link to two that i know of http://www.blackrobotics.com/ and http://www.speedohealer.com/ used them both and both are easy to fit live, earth, speedo in and out. Both are calibrated the same way with dip switches and of the two the speedohealer has the slightly wider range of adjustment.
Kevin
Regards Kevin
