gen1 Plans gone to pott!!!
Started by alban1973, September 12, 2006, 05:31:46 PM
travellinbob
Bloody hell you are a lucky git!!! that looks like a crackin wee car mate. nice one. Hope mot goes through no bother for you.
 cheers, michael.
alban1973
Got new fuel filter and oil filter yesterday so fitted those and replaced the oil, plugs and air filter on its way today. so I though I better check it runs ok today and fit the plugs and airfilter, put fresh fuel in etc ready to take it for the test at 4.30pm  it was a bit kangarooy last time i took it out, but the fuel was old and low also the filter looked dirty , but realised last night 8.45pm that the test was at 8.30 am.  Had to rush out get some fuel, and then hope for the best and that it ran ok and didnt brake down...  Anyway no probs at all, advisers on 3 of the tyres which are low but still legal.
Views on the drive. starts fine hot and cold, just a bit tricky with the screw driver key. ticks over lovely and smooth and it is very different to the elford, power delivery is progressive and actually faster than it feels.  The elford is very lazy and pulls hard from low revs, where this one you have to change two gears to get the power. it is a much smoother ride and a bit quieter, there is a little transmission noise in the first 2 gears, more so when hot but nothing serious. Steering, not as bad as i was expecting from all the talk of other gen 1 ser3 owners, there is a little more play, but not a lot, the most noticeable thing is the box centre position is slightly one sided, so turning right does not have much slop, but it is all on the turning left side, if the steering joints were adjusted so it was central it would be as good as the elford..
So thats the end of that tail..  Charley has first dibbs on it, he maybe needs a bit of encouragement to temp him into rx ownership from you lot..but if he decides its not for him then if anyone else wants a straight, very solid and presentable gen 1 with a bit of interior work necessary, its here in my yard.  or it will go on ebay..
1982 Elford turbo
Jaguar sovereign 4.0
citroen Xantia 1.9td
Mazda 626 2.2 4wd
Some Vans
grinder
i know for a fact that shaun will want it :D
lets see what charlies says eh ??
Stu
The tightest man on earth
:Giggle
shaunwil
Yes please, after all you did out bid me on ebay !
If charley doesn\'t want it tell me how much you want and i\'ll see what i can do.
Shaun
shaunwil
Quote from: grinderi know for a fact that shaun will want it :D
Stu
Yep, stu had to sit through me rambling about it on monday night for over an hr !
Shaun
alban1973
No problems there,   I have fitted the new plugs and the air filter now. plugs were very clean that came out.  I will try to get the wheels off over the weekend and have a look at the brakes, they performed excellently on the rollers, but it has locking nuts with no key, CAn\'t sell it like that.  need to know how worn the pads are, and splash some greese about..... i will keep you informed
1982 Elford turbo
Mazda 626 2.2 4wd
Some Vans
alban1973
Quote from: mpk490pNice one, if you need any bits for it give me a shout
Mark
Thanks mark, there will be a few bits needed,  I need 4 wheel nuts for a start????
1982 Elford turbo
Mazda 626 2.2 4wd
Some Vans
mpk490p
what type of locking nuts are they?
i have a extractor for just that job
set of nuts should be fine
Mark
travellinbob
Allan, post up a pick if you can of the locking nuts as I have a spare key left over from a car ages ago. Its a long shot but someone might have one for you?
 cheers, michael.
alban1973
Thanks, but I have removed them now, The amount of people who loose the keys is astounding.... I must do about 3 out of 10 cars i work on.   just a bit if a chisel, and then big hammer and a 16 or 18mm socket, they soon come off... I just need 4 standard nuts now if you have any..
1982 Elford turbo
Mazda 626 2.2 4wd
Some Vans
alban1973
Ok.. an update on the black car.  I spoke to Charlie yesterday, he has decided he wants a more \'normal\' car as he need one every day. and cannot justifiy having another one with his other projects, so thats fair enough.  If anyone out there is still interested then let me know.   I will update on what I have done.   It has 12 months MOT, I have serviced it, new plugs, oil filter, air filter, fuel filter. I have removed the locking wheel nuts,I have found some normal replacements, I have not had time to look at the brakes, i will service them and replace anything that needs doing over the weekend.    So that is where it stands. the ignition lock is all bust but I just use a screw driver, I am on the lookout for one but no luck so far.  the colum surround is also bust, the door pockets hace been cut for some reason, the centre consule lid is loose, apart from that it is fine.... Not sure what it is worth, I have about £400 in it now, so I suppose offers around £500 ...  If you want to come and have a look it is well worth it..  just let me know..  If not It will go back on ebay......
1982 Elford turbo
Mazda 626 2.2 4wd
Some Vans
shaunwil
I would love to own this car !!!!!! As said i\'ll be definately interested in it. Is it a car i can use for everyday commuting (on lpg) ??? Would you take 450 for it, would have to raid my savings but sounds well worth it !
Shaun
alban1973
Shaun. come over and have a look, at least then you can see for yourself, I am busy tomorrow morning prob till after lunch, but should be around after that.. you cant really go wrong at that price with the general condition of the thing, even the rear axle brake pipes have been replaced with genuine mazda metal ones I noticed the other day.  I will be looking at the brakes when I get back tomorrow.........I can also tax it at extra cost if anyone wants that doing...
1982 Elford turbo
Mazda 626 2.2 4wd
Some Vans
shaunwil
Im taking my 3rd gen in in the morning to get the laser alignment sorted after the syspension mods. I\'ll probably sorn it anyway until i can get the lpg kit plumbed in.
Could you pm me your home address and i\'ll try and pop up to have a look. Would you be at home sunday, may have a run up.
Shaun
