Silicone Hose Adhesive for Rats Nest.
Started by JiM B, September 04, 2006, 10:36:29 AM
JiM B
I’m looking to replace the vacuum hoses on my FD in the next couple of weeks, I’ve ordered Samco silicone hose and tie wraps, but was wondering which if any adhesive I should use?
I’ve read lots of posts and web sites about changing the rats nest and I’ve only found one suggestion that I should use 3M Super Weatherstrip Adhesive.
Did any of you use adhesive, if so what, or is this not really required?
Thanks,
Jim.
kev-yorks
A cable tie will suffice or if you want to glue as well just use a drop of super glue.
Kevin
Regards Kevin
JiM B
Thanks Kevin, think I will stick with just using a cable tie.
