Aircon removal.
Started by JamesFD3, December 25, 2004, 07:37:36 PM
JamesFD3
Anyone on here done this job themselves?
Apart from the obvious of having the system professionally de-gassed before I start,is it a fairly straightforward job?
I will be removing the compressor,aircon rad and I understand the heater box under the dash has to be gutted and modified to allow for hot and cold airflow?
Any helpful tips much appreciated.
James
jonrx7uk
QuoteI understand the heater box under the dash has to be gutted and modified to allow for hot and cold airflow?
I didn\'t do this when i did mine last year, and the heater controls work absolutely fine...
It is quite straightforward really, just tricky getting the bolts for the pump and the pipes themselves out.
1st thing is to take off your existing belt and measure up for a new one (piece of string or whatever) or the power steering will not work.  I got a new belt from local motor factors for about a fiver.
Underbody tray has to come off to remove the air-con radiator.
Took about 2 Hours
Good luck
Jon
JamesFD3
Cheers Jon!
Sounds like a fairly straightforward task,thanks for your help.
James
jamie_eaton
Is there any sites that have instructions on how to do this? i\'ve been meaning to do this myself for months, it has allready been emptied though, slight mistake by myself!
monkey-fd3s
I took the heat exchanger out of my car and it was a bitch.... you need to to retain the box it sits in so don\'t knacker it when you are trying to get it out...
You don\'t have to do it by any means but if you want to make sure you undo all the clips and bolts which hold it in place.  The easiest way is to remove the glove box whilst you work on it but even then it\'s tricky.
jamie_eaton
cheers!! ill have a go soon
memski
It\'s a pretty straightforward job, and it\'s satisfying to rip out the condensor that sits blocking the rad  :Hammer
Haven\'t got round to removing the heat exchanger yet but have done it on a previous car as monkey has already described, should be well worth it when it\'s done :)
Gman
Is the new belt that is needed a fixed size or is each car different?  If its the same does anyone know what size it is?
Donato
Quote from: GmanIs the new belt that is needed a fixed size or is each car different?  If its the same does anyone know what size it is?
Fixed size, just cant remember what it is, Pip sells them off the shelf...i would imagine the others do too...
Tintin
Any body got any more info on removing the heat exchanger or is it pretty self explanatry once you break your spine to see what your doing ???
12.8@110.64 at RS4:Thumbs-up
Ada7
Blimey all you guys are taking your out and i\'m trying to fix mine! Make sure you keep some parts handy. Might need them very soon :rollin
Adam
I AM HERCULESIAN
Tintin
Sorry mate I\'ve already sold all the under bonnet stuff , I\'ll put the stuff from inside to one side for the time being just in case you need owt ( thats if I get round to taking it out ) main priority is putting the engine back together , can\'t wait to fire her back up :D
Jesus just realised its been 5 months since she went pop
