10-7-7 boost
Started by Crazy Eddie, August 24, 2006, 11:38:48 PM
Crazy Eddie
Hi Guys,
Quick question my car has been running at 10-7-10 psi and has been great.
Fitted a cold air feed today and took out for spin and only produced 10-7-7 and seems a bit flatter up to redline.
Could I have done something or does this sound like a second turbo problem.
Quite new to ownership so any help really is appreciated.
Eddie
gsb876
The way i llok at things is that if it was running spot on before you intervened then you have created something for it to go wrong if that makes sense ? :Laugh
So have a look through all the piping to make sure nothing is leaking or loose, also where have you introduced the cold air feed into ?
Crazy Eddie
There is a hole out of the top of the standard intercooler ducting so from that to air filter:3Confused
Crazy Eddie
Thanks for help it looks like it was me!
Got in car this morning and noticed that car mat was pushed under throtle so was preventing me giving it full throtle :Hammer
well I hope so anyway but boosting fine again now :)
G@NDY
QuoteGot in car this morning and noticed that car mat was pushed under throtle so was preventing me giving it full throtle
:rollin :rollin Classic, wish all rotary problems were fixed so easily.:Giggle
gsb876
Damn and theres me trying to think what the problem could be as there shouldn\'t be one :spank :rollin :rollin :rollin
nikp
I was trying to think of all the solenoids, air intake hoses perhaps loose, vacuum hose had come off from this bit, or that bit. Nice simple fix though!!
