Coolant alarm on fresh engine
Started by nikp, August 18, 2006, 06:30:57 PM
nikp
Ok,
I have finally got everything in the engine, all electrics connected, everything connected everywhere else, oil, coolant, fingers crossed. Even the battery is charged and in! :p
I turn the ignition on to check ECU, and switchs, sensors and output, all looks good, but the coolant alarm is going off! :mad: I know i have the low coolant level sensor plugged into the correct wire as i had to put a new one on a while back, so that was easy to spot, sensor is brand new too. So what\'s going on? I\'m a bit reluctant to start the car with the coolant alarm going off, even though i know there\'s enough coolant in it (Unplugged the cable from the box making the noise for now).
Can anyone point me in the right direction....pleeeeeaaaaassse! :)
Gman
Have you got the right plugs connected near the back of the p/s pump?
nikp
Does that make a difference?
What plugs can i mix up? There\'s temp sensor, oil pressure, power steering and air con! How many of those can i get muddled up?
DRAGON
You have proberly mixed up the air-con and the water level spade connectors. Connect them properly and the buzzer will go off.
