Apexi Power FC on Standard FD RX-7.
Started by JiM B, August 22, 2006, 10:54:48 AM
ds2000
Without the CAT or a boost controller you could get some serious spikes even now, so be careful with it.  Does your boost gauge measure in PSI or BAR?
If its bar then 6-5-7 seems ok to me :)
PIPFC
no!!, reads in psi but doesn\'t spike (if it\'s what i think mean)although slight drop in power when the turbo switches over at 4250rpm. what do you reckon? turbo problem or fuelling? maybe the ecu wont let it boost up to 10 psi if it sense\'s it will run lean. i dont if the ecu is that itelligent,lol. just an idea!!
Some People Are Like Slinkies - Not Really Good For Anything But They Bring A Smile To Your Face When Pushed Down The Stairs
