Removing air-con
Started by Devil\'s Refugee, August 16, 2006, 08:48:25 AM
Devil\'s Refugee
How easy is it to remove the air-con unit ?
Do I need to blank off anything, bypass pulleys ??
Living in Scotland, I doubt I\'ll need it that often :evillaugh
Will it make a big difference in the amount of space available at the front for larger rad/ ic set ups ?
You can buy a shorter belt to remove the air-con but other than weight loss you won\'t actualy gain anything or any extra room for mods
RAW
wouldn\'t removing the a/c condenser from in front of the radiator give better airflow and cooler water?
nikp
Wouldn\'t have thought it would make a noticeable difference.
