Dangly wire from sump!
Started by iaint, July 04, 2006, 02:52:45 PM
iaint
Hi,
While lying under the car last saturday doing an oil change I noticed a wire dangling down from the sump.  It\'s connected to some kind of sandwich plate on the opposite side of the sump from teh drain plug.
It\'s other end should be attached somewhere but I\'ve no clue where!  It\'s a single wire so I assume it\'s earthed through the chassis.
Car seems to be running fine without it though!
nikp
Isn\'t that the oil level sensor? Not all FD\'s have them i think. Not 100% on this though. (It\'s too hot for me to go and check my sump! :p)
iaint
Maybe!  Looks a bit low though.  any more ideas/confirmation people?
cjr
oil level sender wire. All FD\'s have these
A small turbo
iaint
Thanks!
Next question... where does the other end attach to and is it important - no warning of any kind displayed!!
What was that flashing red light on the way back Sunday? You sure there\'s no warning lights. :p
cjr
white plug that comes off the starter motor loom. they generaly hang down once the engine has been disturbed. If your worried make sure it is plugged in and cabletie it up out off the way
A small turbo
