advice plz
Started by zed, June 07, 2006, 09:09:32 AM
zed
hello
need help plz. in the last few days when i start my car it fires up fine but then feels like its gonna cut out. its not when i first start car up in morning but after short trips during the day. Could this be related to the hot weather weve had last coule of days.
cheers
STi_Ver.4
hi guys
come on people how about a little help here please
cheers
I think you need more info?
Does it have anything done to it?
Are you using your Air con?
How short a trip?
Do you do alot of Short trips in it? Not getting it warm?
zed
hi mate
thanks for reply my car is standard .not using air con.
the short runs are about 10 mins. for examplewhen i start the car this morning everything will be ok. do my first journey ,park up for about 20 mins and then start it up again while the engine is still warm, that is when the problem occurs. its like the there is no idle control.
cheers
framey
I have a very similar problem.
After a hot/warm start it frequently dies soon after. However, it starts again without problem and is ok from then on???!!!
I was thinking along the lines of some sort of malfunction in the cold start system? Maybe it\'s coming on everytime?
Was going to take it to a specialist but funds are a bit tight at the mo. But when the situation improves I\'ll have an expert look at it.
Sorry I couldn\'t of been more help.
ps if you sort it - let me know!!
Laeeq
I did call you Zed the same day you posted here...but no reply.
Is the problem sorted yet or not??
Laeeq
zed
hi laeeq
sorry my friend but ive got a new phone and the reception at home is crap.
i havnt driven it today but i will check it 2morow. i ring u
nikp
You could try adjusting the idle screw at the throttle body. when cold it has an accelerated cold start procedure which could allow it to idle fine, but then when warm should idle by itself - it\'s possible that if the idle screw was not adjusted correctly it could be trying to idle too low.
