Injectors Bosch 850/1000/1300cc uprated-part No\'s??
Started by rx7_bhp500, November 15, 2005, 04:36:31 PM
rx7_bhp500
Hi
Has anyone tried Bosch uprated injectors ?
I\'m going to be buying various bits over a couple of months for Single turbo
conversion + uprated injectors + ecu etc etc...
Assumptions:
Top feed injectors would require aftermarket injector rail.
FD injectors are always low impendance ?? std are 13.5 ohm ..?
Q1 = does an Apexi (for eg) adapt for high or low impendance, are there more
        choices when it comes to injectors?
I have 3 options :
1. expensive = injector rails + top feed 1000cc or 1300cc Sard\'s or whatever.
2. budget = existing rails + Bosch side feeds (if they exist)
3. budget2 = 850cc x4 using existing rail...
Q2 : Is anyone aware of correct Bosch part No\'s for 850/1000/1300cc side feeds ?
Iwan
Quote from: rx7_bhp500Hi
they are few people out there running 1680cc Bosch units, so YES!
Quote from: rx7_bhp500I\'m going to be buying various bits over a couple of months for Single turbo
Assumptions:
YES them will do!
Quote from: rx7_bhp500FD injectors are always low impendance ?? std are 13.5 ohm ..?
NO, 13,5 OHM are HIGH impedance. Low imp- units are in range of 2 Ohms.
Quote from: rx7_bhp500Q1 = does an Apexi (for eg) adapt for high or low impendance, are there more
Runnin PFC will requere to use high impedance. Can be done soldering 10 ohm resistors into Inj. wire.
Quote from: rx7_bhp500I have 3 options :
They are no 1300cc SARS (or also called DENSO) units avaliable. If anybody sell them as 1300cc them may be bored units. Only 1000cc DENSO units are avaliable. Them can be used with SARD fuel rail. Running 4x1000cc will give you arround 520 Flywheel HP.
Quote from: rx7_bhp5002. budget = existing rails + Bosch side feeds (if they exist)
Never heard about such big Bosch side feed injectors.
Quote from: rx7_bhp5003. budget2 = 850cc x4 using existing rail...
very common setup, will requere some tuning job on PFC, good for about 450 flywheel HP
Quote from: rx7_bhp500Q2 : Is anyone aware of correct Bosch part No\'s for 850/1000/1300cc side feeds ?
They are no such big Bosch side feed injectors on the market.
Quote from: rx7_bhp500Thanks
You welcome!
still remember,
NO ROTOR, NO MOTOR !
rx7_bhp500
thanks for update...
another forum post - someone said FD\'s use low impendance...doh !!
crispyj
Will the PFC cope with running low impedance injectors with no resistor in series ?
Or will it pop the output transistors ?
I have heard of people running low resistance injectors without a resistor with no issues.
Thanks Nismo9
