power fc
Started by adib, May 05, 2006, 01:24:08 AM
vxer
Quote from: Stu.WilsonHi ya mate, wat i ended up doing with mine was setting idle at 900rpm a little high i know but cut the hunting out. This is what i set mine too, until i get it prof tuned -
F/C A.E 1400
F/C E/C 1450
F/C A/C 1450
IDLE A.E 900
IDLE E/L 1000
IDLE A/C 1050
Hope this gives a rough idea, it worked fine on my motor. You HAVE to keep the value between Idle setting & F/C setting above 100rpm.
catch ya at RSIII, Cheers Stu
Thanks stu, i\'ll give these a go. Its funny - if these values work fine, its a wonder the even bother with the self learning process because its clearly broken! :-)
Ta, Paul.
adib
never got round to putting mine in will be having ago this weekend if rain keeps off, booked it in to be tuned at wgt next saturday
adib
power fc in no problems apart from rain again, when you go to etc-input output should the reading be near to the ones in the instructoins because mine are all a lot higher apart from intake air temp sensor have any of you guys got any readings off your car
vxer
Quote from: adibpower fc in no problems apart from rain again, when you go to etc-input output should the reading be near to the ones in the instructoins because mine are all a lot higher apart from intake air temp sensor have any of you guys got any readings off your car
What in particular?
Ta, Paul.
Kash_
Hi guys, how much did the power FC cost you and where did you order it from? Thanks
adib
ebay, place in japan 399 pounds but had to wait 3 weeks for it to come and 40ish pounds import tax
D2BBA
Try Nengun performance on the internet.  Both Power FC and commander for £400 with all taxes in (I think!)
Chris
Don\'t supose you have a Link handy :)
vxer
Quote from: adibebay, place in japan 399 pounds but had to wait 3 weeks for it to come and 40ish pounds import tax
Got it from the same place - took about the same amount of time, but didn\'t have to pay vat or tax!  :Santa
Stu.Wilson
Got mine from RHD (//www.rhdjapan.com) cost £414 all in (delivery & unit, managed to get away with not paying duty!), ordered it on the Friday and got it on the Tue! super fast delivery with constant contact with them. Only thing is you have to download instructions, unless your fluent in japanese! LOL.
Or if ya want to feel safer by buying in the Uk your looking at around £650-£700, but you do have some come back with UK guys if it goes wrong.
Cheers Stu
See ya all at RSIII
adib
399 was power fc and comander and if you dont get hit by tax your lucky, be shore you get right one, there is an 8 bit one or 16 bit one
adib
399 power fc and comander, and if your buying one get the right one as there is an 8 bit one for 92 to 95 and 16 bit for 95 on, think my dates are right
Stu.Wilson
Quote from: adib399 power fc and comander, and if your buying one get the right one as there is an 8 bit one for 92 to 95 and 16 bit for 95 on, think my dates are right
Yep think your right 8bit up to \'95 and 16bit after \'95. yep mine is def correct model and commander, getting it tuned next week too.
If anyone ever wants more info on the correct models and commanders for the power Fc \'nick\' has posted some excellent threads.
Cheers Stu
16 bit came in late on in 95
You can tell the Diffrence, 8 bit has Four plugs and 16 bit has three. I think :)
