Lardy Rex ?
Started by Prof, May 24, 2006, 08:09:45 AM
Just been checking the MOT certificate - I know, how sad is that ! :(
Weight is shown as 1560 Kg !!!  :2eek  :2eek
I thought the weight of the Vert was nearer 1460Kg - so was my weigh-in with a bloater of an MOT tester sat in the car, or have I gained some extra weight ?  :3Confused
BTW - I don\'t think it\'s my iPod :D
MikeLMR
if the 1460Kg was a book figure it was probably a dry weight, add fuel, water, oil etc. and they get a bit heavier (+ the manufacturers tend to tell lies when selling cars :eek )
How much does a tank of fuel weigh ? - although I was only a 1/3rd full for the MOT in any case.
MikeLMR
about 737g a litre
oil is about 880-940g a litre
water is of course 1Kg per litre
So assuming 20litres of petrol, 5 litres oil, about the same for water (in all the bottles and the coolant)  That gives about 15+4+5 = 24 Kg
Let\'s assume the toolkit, jump leads air pump and stuff come in at 10Kg
That still leaves a hefty 66 Kg\'s somewhere - so maybe the MOT guy is not so big after all !!!   ;)
grinder
they weighed your car for the MOT - how wierd is that ?
The tightest man on earth
:Giggle
MikeLMR
are you sure they weighed it ? or did they go off the data plates on the car ? some of those are fully laiden weights.
Really not sure to be honest Mike - it\'s in the brake test section.  I hadn\'t noticed it before on the last one.
Pleased with the emissions though - I\'m chucking out half the junk that a fella at work makes out of the back of his Vauxhall - which is with CAT and has just had it\'s first MOT !  :eek
  I got 0.44% CO and 244 ppm HydroCarbons - so my car is practically farting fresh air ! :D
Thanks for the petrol / oil weights.  Probably doesn\'t make much difference as I weigh in at 105 Kg so my 1/4 mile will not suffer much - That\'s the problem with Beer !  :guinness
g.miller
i help the guy mot my old MGB the other day and we had to look up the weight of the car on a wall chart,
[took a while because it was listed under Morris] so they don\'t actually weigh the car just get an approx. weight off the chart.
Grant
Are - so it could be off a chart - Thanks grant.
Does anyone know of a weigh bridge near me - Surrey / Berkshire / Hampshire border ?
Be nice to know the actual weight! :cool
g.miller
Prof.
you could look for scrap metal merchants in the yellow pages or try land fill sites most have weigh-bridge\'s.
hope this helps
Grant
