intercooler
Started by davyv, May 22, 2006, 09:01:04 PM
davyv
changing my intercooler,what\'s the biggest fmi you can fit and any advice pls.Not going for a v mount because i already have a custom made Ron Davis rad with twin fans. Thanks
Jonathan_F
My car is fitted with a HKS intercooler. Its 4 inches short of full width and mounts infront of the rad. Works well but if your rad is close to the front you will struggle to get it low enough because of the angled exit pipe in the top. Its very well made and the best I\'ve seen. Cast ends look to flow very cleanly over fabrications. I have fitted a small batery and moved the rad back to get it to fit.
Sorry I\'m not being too exact.
I\'d have a mooch around rotorstock with a tape measure. See you there if you want a look.
Jon
