Fuel leak
Started by probedb, May 17, 2006, 09:20:56 AM
probedb
Just a quick check to see if this sounds ok.
Got round to fitting the racing suction kit I bought from g@ndy last night. In the couse of fitting I must\'ve pushed the metal vacuum pipes that run down past the turbo against the banjo bolt and it was leaking.
I\'ve since managed to sort it so it\'s not pushing against it and ran the car for a few minutes and it\'s not leaked. Any thoughts on why a simple bit of pressure caused a leak? It\'s not loose at all.
Going to check again tonight and go for a drive and test it.
Cheers!
