Vandals
Started by Matt_P, October 29, 2003, 11:00:01 AM
Matt_P
A neighbour of my sister in law who happens to own a nice 1st Gen Rx7 has had expanding foam sprayed up his exhaust... Is this gonna be replace the exhaust system job and if so how much is he looking at? any help or advice would be appreciated!
Matt P
RX-7_SEUK
I hope he doesnt have to replace it....big ££££\'s!  Rotechniks do a replacement, have a look at their site:
Rotechniks
maximtaylor
What I would do:
Shove a metal rod up the pipe to clear a basic path through for gas, get a fire extinguisher ready at the back of the car and start the engine.
The exhaust should melt/blow/burn the crap out hopefully!!
Regards
Max
Matt_P
worse thing is the **** who did he will most likely get away with it and even were they caught i doubt they will have to pay anything towards it! i really hope he dont have to replace it.. its a lovely looking car, just a shame certain elements of society dont show more respect for peoples pride and joy :reallymad
Matt
RX-7_SEUK
Always the way i\'m afraid mate.  Mine is safe as houses, locked up in a garage in the middle of the country!
bill shurvinton
See if acetone or petrol will dissolve it.
MikeLMR
you can buy stuff to remove expanding foam
http://www.screwfix.com/app/sfd/cat/pro.jsp?id=24412&ts=28514
you might need to take the back box off to soak it in the stuff but its cheaper than a new one
gyrpere123
go to any pvc trim company that supplies the window companies in your area and ask for a tin of foam gun cleaner, this will break it down but you will need to stand the exhaust  on end and allow the cleaner to soak in overnight keep topping it up and do it out side were its cold then it wont evaporate as quick then turn it over and repeat. Also keep trying to shove something in to it, its not hard when set and with a little time it will come out. The cleaner costs about £3.00 if that. Hope this helps MARK.
