Electric Radiator FAN on FC
Started by Prof, May 08, 2006, 12:47:03 AM
Does anyone know if this can be done ?
Parts manual seems to suggest it was available, but I have never seen them for sale anyplace.
Any ideas?
Anyone got one for sale ?
Yes it can be done.
I personaly fitted a 16" Spal fan from Demon Tweeks then i Drilled and tapped the water pump Housing and fitted a temp Sender, bit of wiring and its done.
have you tried Serching on the second gen section? i\'m sure this has come up before.
Cheers,
I found it now !  :rolleyes:
Obviously time for bed ...
