Tacho/Revs dial works interimitently, why?
Started by GAZ666, May 04, 2006, 07:40:00 PM
GAZ666
The needle on the tacho decides to stop working now and again, it does affect anything else engine wise....
What could be the cause of this?
rx7veilside
they are well known for either jumping or just not working ..best get a new or 2nd hand one ..mine used to jump between 3-4500
Mave
Make sure the live terminal on the battery is secure; whenever my rev counte rjumps it\'s because the terminal is loose, a jon for this weekend is sorting it out properly...
GAZ666
no loose connections......
buy what 2nd hand? new instrument cluster?
Eddie
When I had this problem I had to get a replacment tacho and just replaced it for the one that was dodgy, problem solved.
I think I may still have a spare if you want one, I shall have a look and let you know
GAZ666
Yeah that will we cool if youve got one...let me know pls mate thanks
