Cable for battery relocation
Started by Tintin, April 25, 2006, 06:44:41 PM
Tintin
I\'m relocating my battery to the boot and just wanted to check about the cable others have used , I\'ve been reasured that 15mm CSA thats about 5 - 6 AWG
I\'ve seen an amp wiring kit in halfrauds that comes with with 4 AWG cable , 120 fuse + holder , and connectors , this will do the job won\'t it ??? I\'m sure I\'ve read that someone used something very similar in the past
12.8@110.64 at RS4:Thumbs-up
Mr J.T
hey im using 4 gauge cable a 150amp blade fuse and works fine there isnt any voltage drop either :) hope this helps
Tintin
Cheers mate ,
I\'m thinking it should be fine , just wanted to double check really
nikp
I\'m just using standard battery cable, as found suplpied by motor factors and spares shops.
