Info on Downpipe and Oil Lines
Started by Gman, March 17, 2006, 11:43:23 AM
t2rew
it might be worth phoning the traders up there ^ to see if they have some flanges then its just some hose and fittings that you can get from demon tweeks
memski
They are usually very quick as long as they have everything they need in stock, will probably give some Uk traders a run for their money!
Gman
Cool, lets hope they get back to me soon.
Now just the downpipe to sort out, the place suggested can\'t do anything till end of April so i need a quicker alternitive.
Mike
Gman, did you get anywhere with the oil lines as I need some? Where are you taking the top one from as the original metal pipe winds across the enigine and then down - I can\'t use the original metal pipe as it got a bit bend when I stepped back... and ... er...
Anyway...
