Stock Oil Pressure Gauge
Started by AshRX, April 02, 2006, 10:36:05 AM
AshRX
After picking up the car from the main dealers i noticed that my oil pressure gauge in the car wasnt working. Can anyone tell me where the plug is located in the engine bay so I can reconnect it if they have unplugged it.
asp
rear end plate on the spark plug side
Jono FD3
Near as dam it under the oil filter on the passenger side of the engine. Could be a dirty connection....... My gauge has a habit of doing what it wants (sitting on 4 then 2, back to 4, then to 0, and back to 4!!) , so I\'ve bought an auxilary gauge for piece of mind!!!
Jono
allstaruk
There notoriusly crap, especially as there under the oil filter so evertime you change the oil they get dripped on, giving a good clean tends to make it work better.
AshRX
cool cheers - got an HKS one that works fine so I know the pressure is fine.
GAZ666
i\'ve just checked mine by grounding it and it didnt work so how do i remove it and fit a replacement... all i could see was the electrical connector attached to a metal plate?
