What temp for warning on water temp gauge?
Started by probedb, April 01, 2006, 09:52:32 PM
probedb
Anyone any thoughts on what temp I should set the warning buzzer on my Defi gauge?
It\'s preset to 100oC which is too low.
Cheers!
Paul.
nikp
I personnally would say about 105. In normal driving conditions you shouldn\'t see temps that high (The fans should have come on by then). The coolant will boil at 129 degrees if thats any help!
probedb
Ok well i\'ll set it a that and see what happens. Cheers!
rx7veilside
depends what temp u have set for the fans to come on..mine is set to 94deg so warning of 100 wld be good as it wld warn that fans are not working
probedb
I\'ve not messed with the fans so they might be set to standard. I\'ve moved it to 105 and it seems to sit around 85 for most of the time.
nikp
85 is good. That\'s what it\'s meant to be. Obviously, bimbling around town for longer periods will mean those temps rise, but as long as they come back down again (When the fans come on at about 100) then you\'ll have nothing to worry about.
probedb
