Sealant when fitting turbo and manifold?
Started by Gman, March 24, 2006, 05:35:21 PM
Gman
I am doing the final fitting of my manifold and turbo tomorrow, should i use sealant when fitting these or will the gaskets be good enough?
Gaskets should be good enough. The problem with using a sealant is that if a bit falls off, it could wreck the turbo!
Do not use sealant pre turbo exhaust housing!
Martiny
Can you even get a sealant capable of seeing 1000c plus?
