fitting Boost controller
Started by Fats, March 03, 2006, 10:33:58 PM
Fats
Just in the middle of fitting my greddy profec A boost controller, just wondering which actuator is for the wastegate, i would have said the one with the adjustable actuator, just want to make sure i fit it correctley with out causing to much damage!
Herblenny
#1
Are you running single or twin. If twins, are you running them sequential or non-seq?
In stock twins, its the top actuator is the wastegate control.
If I recall you would have to "T" both wastegate and precontrol together. Follow your Greddy/Trust manual.
Also don\'t use cheap silicone tubing. If your tubing melts, you will not be able to control boost and you will over boost. Also, make your lines as short as possible.
1993 MB RX-7 Touring "FEED"
1991 Eunos Cosmo 20B Type-S blk/blk
Organizer of //www.DealsGapRotaryRally.com
Co-Owner of //www.RotaryCarClub.com
Follow me on Instagram for cool rotary pics and my projects!
http://instagram.com/herblenny/
Fats
Alright mate, im running standard seq turbos, i\'ve had a look at the greddy site it dos\'nt show diagrams for the twin turbo setup, have you got any info? cheers
Andy
nikp
Yeah, cos it\'s sequential, you need to make sure you\'re controlling the boost on both the primary and secondary turbos. For the primary turbo, most of the time, the boost is actually regulated by the pre-control actuator, rather than the wastegate. Therefore, as Herblenny says, you need to T-piece those together, and then to the boost controller.
Fats
