Fuel Mixture adjustment /MOT
Started by Andy T, March 03, 2006, 07:21:48 PM
Andy T
Hi,
Can someone let me know what I can do with the Apexi PFC to lower my emissions a tad before the car goes for an MOT.... I am just a little wary about the emissions as a beleive most of the FD run border line with the emissions
Andy
maximtaylor
Main menu - settings - IGL/T,Fi.
You\'ll now be in a screen with "IGL   IGT    Inj Adj" across the top.
Go to the top box on the right, under Inj Adj where there is 1.000
This will trim down your overall fuelling, so to take out 5% reduce it to 0.95 using the down arrow.
When you turn ignition off then on again, it will reset to 1.000 as before.
Don\'t try driving with it leaned out, only do this for the emissions check.
If you still have a/c, turn it on - it helps sometimes.
