strange experience twice now
Started by michaelb, February 05, 2006, 04:51:05 PM
michaelb
it does feel like a sudden fuel cut....no power for 0.5 seconds and back to normal...but I am stepping on it big time in 5th gear
Regards,
Michaelb
Quote from: royston1xxExactly, in 5th gear there is more load which would also give more time to boost creep slightly and hit fuel cut. This is exactly what used to happen to my car 7 years ago while i was still close to stock - fine in the lower gears and fuel cut in the higher gears. Take it as you will :)
Carl
Quote from: michaelbI heard a grinding noise( not a bang )  for a split second and the car defiantly pulled back…Quite a nasty noise possibly coming from somewhere behind me under the car.
The engine was rebuilt about 2 years ago and the car just had an engine service at Rotechnics.
Regards,
Michaelb
Did it sound like someone dropping a load of nuts and bolts into the exhaust?Like a mettallic loud rattle? If so it to me would still be det.
Regards
Carl
michaelb
I had a service at Rotechnics about 5 weeks ago...
Quote from: royston1xxAlso, when did you last change the fuel filter and plugs?
michaelb
Hi Carl
no rattle just a deep grinding noise for 0.5 sec..
Regards,
Michaelb
Quote from: CarlDid it sound like someone dropping a load of nuts and bolts into the exhaust?Like a mettallic loud rattle? If so it to me would still be det.
Regards
Carl
royston1xx
Sorry, i missed that bit. Does it happen around 5500-6500rpm and feel a bit like the rev limiter?
royston1xx
Sorry, i missed that bit. Does it happen around 5500-6500rpm and feel a bit like the rev limiter? As that is where my car used to do it.
michaelb
it has only happened twice in the last 8 weeks not all the time...it does feel like a limiter but it is not...
Regards,
Michaelb
Quote from: royston1xxSorry, i missed that bit. Does it happen around 5500-6500rpm and feel a bit like the rev limiter?
Carl
Royston could be right about the problem then.
I do think that you should either stop doing 150 mph,or get it tuned with a power FC!
Regards
Carl
