can you help! silicone boost tubes
Started by matrx7, December 19, 2005, 05:28:53 PM
matrx7
I keep having boost tubes going on second turbo, on my last rex i got all the tubes changed for silicone, but got someone else to do it and it ended up costing me a few quid. I would like to have a go myself this time, how much hassle is it for a novice, coz i know its like spagetti junction?? Also does anyone know of anywhere you can buy the hoses and what size?? Thanks
Jono FD3
The Turbo pipes them selves are a dodle to do, any muppet with a screwdriver can fit them as they only go one way!!!!
But if your on about the vacuum pipes under the plenum then thats a different story!!!
A bit of time to be taken doing that job!!
matrx7
Yeah the vacuum hoses thats the one! Are they a major job, could a novice do it or would it be too much???
Jono FD3
From what I have heard a novice can do it but it\'s advisable to take your time!! There is a hot to on this somwhere on MRC!
I\'m looking at doing this at some time and what I normaly do when in unfamiliar teritory is number every pipe thats disconected (pipe & recieving pipe) so you know they are going back ing the right place!!
I know this isnt much help, Sorry!!
Jono
deanflowers
http://robrobinette.com/hoses.htm
is quite helpful
there are a range of sizes and somewhere on the net i remember seeing a kit that stated the lengths and sizes of the pipes you would need
matrx7
Thanks for your time and help, that link looks usefull, i might give it a go!!
If i get in to trouble i have got someone to fall back on, i will let you know how much hassle it is
thanks
