3 bar map sensor
Started by asp, December 03, 2005, 10:58:02 PM
asp
how do you go about fitting 1,is the plug the same as stock fd 1,
is there a 3 bar map sensor that i can just straight swop with the fd 1?
cheers
What other mods do you have? If you have the PFC you will need  to adjust the settings for it.
maximtaylor
Just to add, you only really need it if you are going to run any more than 1.2 bar.
asp
bridge port with gt35r,iv got a datalogit to change the settings,
asp
Quote from: maximtaylorJust to add, you only really need it if you are going to run any more than 1.2 bar.
thats why i want 1 :D
maximtaylor
:) Have fun!!
Quote from: aspthats why i want 1 :D
asp
found the info i needed,
for gm 3bar the plug will not fit so hears the new wiring
    3bar       ........                   fd wires
a/grnd/                             black
b/map sensor volts/            green yellow
c/5v/                               brown white
MillSpeed
Sh*it mate, can\'t wait till it\'s goin....tis gonna be fookin brutal!
asp
Quote from: MillSpeedSh*it mate, can\'t wait till it\'s goin....tis gonna be fookin brutal!
i hope so,still got to get a few things,but thay can wait till its run in,
