Tuning Stages
Started by mr_tim, September 02, 2003, 05:31:12 PM
mr_tim
What would be a wise Stage 1/2/3/4 tuning package for the FD?
20B_boy
If you\'re setting off on a fairly inclusive tuning adventure then do it the \'right way\'; get the fuel system and engine management sorted out first. Consider your performance goals VERY CAREFULLY and source, build and install an adequate fuel delivery and management package. You cant go wrong from there...
JMO - sensible head on :-)
R.
R.
1 - stereo & neons
2 - Alloys & suspension
3 - tint windows & new wing
4 - respray
Sorted
mr_tim
so something along the lines of uprated fuel pump and secondary injectors along with a PFC to control the fuelling be a good start?
And then the real fun can begin. I think i\'d only want to go upto around 330bhp as i want to stay with the sequential twins. So what would you recommend?
Of course scope for more in the future might be nice.
OK, my idea of whats needed for 330BHP.
Apexi PFC or other adjustable ECU
Uprated fuel pump
Fluffy dice hanging from the rear view mirror
After market fuel pressure regulator
Cat less exhaust system
Neons/strobes pulsing with the bass note
Pimp tints
That should about cover it.
Dan
Oh also a set of brake pads that will stop you when required. ;)
mr_tim
Thanks - gives me some idea of what to aim for. not sure i\'ll be getting everything on your list though;)
Sorry, I must have been reading to many of OJ\'s posts. :p to the bish!
Dan
Jus
QuoteOriginally posted by mr_tim
Stage one
Boost kept to 10-psi max
Radiator (alloy)
AST (Alloy)
Change thermostat
Change fuel filter
Stage 2
Ecu (PFC or Microtech, imo)
Cat back exhaust
Aftermarket down pipe (keep the cat)
Stage 3 looking at more boost 13-14psi max (stock twins)
Up rated pump (walbro 255 example)
1200cc but better off with 1600cc should you want to go to Stage 4
Fuel Reg.
ECU re-map
Intercooler upgrade
Intake (not really needed, stock one does a great job)
Stage 4
Single Turbo conversion (all the goddies)
Decent Clutch
Modified fuel rail (1600cc)
Resistor if running PFC ecu (change injector imp)
Boost controller
Mid pipe replacing CAT
Re-map
Stage 5
Engine rebuild..... To your preference, yum yum....
Possibles to remove....
Air Pump
Power Steering
Possibles to fit
Electric water pump, replacing stock water pump.
That should be it..... Not mentioned Brakes and Suspension.
Hope that helps.
Regards....
Jus
mr_tim
sounds like a plan - thanks for that
