fd counter weight
Started by asp, November 04, 2005, 09:35:28 PM
asp
whats the difference between the auto and the stick shift counter weight?
Carl
The manual gearbox has the weight incorporated into the flywheel.
The auot uses a seperate counterweight.
The auto counterweight is used along with aftermarket flywheels that are generally lighter than the stock cast iron ones and usually are able to handle higher rpm safely as they are either billet Steel,or an Ally and Steel combo.
Regards
Carl
asp
i bought 1 some time ago (auto) just in case i needed it,                             any way i just bought a os clutch and fly wheel which came with a counter weight,funny thing is i took the counter weight of my own fly wheel all 3 look and weight the same (3lb 14oz),
cheers carl :)
