Which Gauge?
Started by ScuttleRX, September 02, 2003, 05:07:45 PM
ScuttleRX
Just ordered a two pod gauge holder, one slot is reserved for a boost gauge but not sure what to use the other one for.
I was thinking either Exhaust Gas temp, oil temp, or air/fuel ratio
Any advice?
Also do gauges come with all the necessary sensors, etc or do you have to buy them seperatly, brand I was thinking of is Defi if that makes a difference.
Andy
mr_tim
get water temp as the stock one is supposedly poo and temp is very important
Andy, if you get the Defi gauge from Nito/Jane at Defi Shop you will get quoted for everything included.
Depending on the mods you have, I would want to fit an oil temp gauge with your boost gauge. That way you will know that the oil temp is up to temp before playing.
Dan
ScuttleRX
What thinking about that orignally but then I found this:
http://www.iluvmyrx7.com/3rdgen/how-to/Temp%20gauge%20mod.pdf
So was thinking about doing this to the water gauge, hopefully eliminating need to replace it and leaving me a spare gauge slot. Has anyone tried or had any success with this?
MikeLMR
I\'d say oil temp ... you\'ll get more use out of than an exhaust temp or air fuel ratio gauge (most aren\'t that accurate anyway)
Mike
Andy, that mod is a bit flakey and doesnt always work. Some have done the mod, then removed it again because it gave some funny readings.
Dan
<--rYaN-->
Defi gauges are good because they match all the stock colors and backlighting etc :)
1999 Type RB-S
My Car
kevint
If you are looking out for overheating then water temp is the one to go for. If you want to know if your engine is up to operating temperature then go for oil temp.
Jane/Nito, UK distributors for Defi gauges, are at //www.defi-shop.co.uk not //www.defi-shop.com.
Kevin
ScuttleRX
Anyone know of a good quality gauge that has a blue backlight?
Have just bought a set of dial faces which are blue and would be cool if they all matched.
Dan Norton
#9
The new Blitz BLM meters are suppose to be pretty nice.....black background but with blue iluminated numbers and needle.
Cant get the pic to download...but heres the link.
http://www.takakaira.co.jp/asp/template.asp?cat=2&id=841&prodID=KLlHiIidfEgcjFe
I run a HKS EL boost gauge in my crx...its bright blue at night with n orange needle.
Dan!!
Turned into the worst part of my life....my precious fd3 has gone, but never forgotten....roll on a new life!!!!
