Main Menu
oil
Started by davyv, September 06, 2005, 07:36:04 PM
davyv
New to RX7, what oil do i use to top up thanks.
g11ary
Do a serach for oils and there are loads of threads,
heres just one.
http://www.mazdarotaryclub.com/forums/showthread.php?t=17876&highlight=oil
If its topping up then you need to know whats in it, would assume its mineral, as that is the most common and cheapest.
If its oil change, then thats a whole can of worms.
the lemster
I used halford enhanced minerla oil 10-40 was fine... though have recently swapped to silkolene XTR 10-40 semi synthetic...  if you ahvent changed th oil since you have had it or have just bought it... I would change the oild and filter asap just for peace of mind...
good luck and welcome....
