ohms on a standard coil
Started by mpk490p, September 06, 2005, 08:11:35 PM
mpk490p
i have a flammer kit and need a coil with a resistance between 5.0k ohms and 6.0k ohms i can\'t find my volt meter but wondered if a standard series 1 coil would do it, would any know?
thanks Mark
McCARTHY
You could use an home audio loudspeaker coil..... they are rated at between 4-8 ohms (make sure you buy the right one). Anywhere like maplins or any good electrical / audio shop should sell them speratly.
mpk490p
it needs to be a car coil as you run a spark lead off it
