General Comments or Advice Reqd
Started by oRi, September 05, 2005, 09:24:34 PM
oRi
This has probably been asked before but how long can a 7 sit without deterorating?
Although its only the battery that has ever gone flat i am concious that other things eg the brakes could bind severly? Is there anything i can do to prevent this/protect against it.
Fairly sure the car wont do much now for the rest of the year.
Any advice would be appreciated.
Stu
t2rew
the best thing to do is put it in a garage. it keeps the weather off it and it will be ok like that for quite a while.
gsb876
Biggest problem is rust, if you leave the handbrake on then it will stick if left too long, best place would be a heated garage, no handbrake on, take wheels off to stop them going flat while on the car, take out battery too.
Donato
Make sure there is plenty coolant/antifreeze in it, dont want it freezing up! Did you decide not to sell it then?
Donato
dandan
I can keep it running for you if you like!
No charge!
the lemster
good section on robrobinette site or is it scudariaciriani ( oir how ever you spell it) on laying your car up for the winter...
