All i want to do is change my oil?
Started by rmagictastic, August 31, 2005, 08:29:27 AM
Donato
There is no reason for an oil filter to be on anymore than hand tight. and make sure you put oil on the O ring of the filter before you tighten it.
The reason you dont get oil pouring out of it is because the oil filter is on top of the engine facing down the way, and the oil is at the bottom of the engine due to gravity  ;)
andrewrx7
Quote from: DonatoT
Ah! that man - he talks sense!  :cool
Kieron
Quote from: davegttph1Hammer a screw driver through it :D
This is the best way to do it, all the oil drains out and you won\'t get it everywhere.
What I am looking for it an adapter to move the oil filter, cucso do them but I can\'t find them for sale anywhere.
GeckoGareth
davegttph1 - Someone told me a while ago that if you buy your oil and filter from ATC then they will do the oil change free of charge. ATC is the company with the yellow logo, I think it\'s ATC but could be ATS !?!
There\'s one in Melton BTW. might be worth giving them a ring
regards
Gareth
davegttph1
Yeah ATS.... although they do tyres IIRC not servicing. This we have 1 in town actually. might be worth giving them a bell then, thanks :)
GeckoGareth
yeah think they do tyres, exhausts and all sorts really. Let us know how you get on if you ring them.
cheers
G
Rich Cheung
I cant change my oil because I cant get under the car to drain the damn oil  dunno what Im going to have to do
 :xconfused I\'ve probably got one of the lowest Rex\'s and I can still get the sissor jack under the front jacking point. TBH I only realised this recently as before I\'d drive up onto a 2" slab on concrete which just allowed me to get the trolley jack under. You could always try that.  :)
Phasen sehnen sich das Hoff
長くHoff は住んでいる
davegttph1
I dont have the jack that should have come with the car so thats a none starter. Im going to have to buy a trolley jack I think. Need 1 this weekend so its probably a good idea to get 1 anyhow.... still like you say Id need to drive onto something to get the rex clearance BUT surely if the cars jacked up all the oil will run to the other side of the engine and not drain?
andrewrx7
OK so mines not lowered or has any after market body kit on, but what I have found, is with the 2 trolley jacks I have, they do not do under the car until it is raised an inch or two. I hate using the Mazda jack, it just seems to not fit well, and scratch the paint on the jack point. So what I now do, is use a small hydraulic jack, that just fits under the front toe hook. Its enough to lift the car that inch or 2, then the trolley jack goes under to the sub frame, where Mazda recommend you jack from. The car is therefore raised evenly, and is not leaning (apart from backwards, of course!). A couple of axle stands for safety, whip out the drain plug, and collect your oil! Guess you could always lower the car again, to get that little extra out, but not sure it will make too much difference anyway!
grinder
i drive mine onto breeze blocks first to get the jack under
davegttph1 - why dont you have a look in the members section for the formoto ( or summat like that ) engine drail valve
could be a good idea for you
ta
stu
The tightest man on earth
:Giggle
davegttph1
Ive seen that valve thing. it was on a group buy wasnt it? still not much help cause the drain bucket doesnt fit under the car so it needs to get raised somehow at somepoint to drain the oil :(
g11ary
If youy turn the wheels on full lock you can slide a trolly jack under and jack from there, once up axel stand and do other side.
RemarkLima
Guys, this lady on eBay sell\'s 75mm ali trolley jacks, ~£150 but well worth it if you plan on doing a lot of work yourself.
http://cgi.ebay.co.uk/NEW-LIGHT-WEIGHT-ALUMINIUM-RALLY-RACING-TROLLEY-JACK_W0QQitemZ7995951895QQcategoryZ30928QQrdZ1QQcmdZViewItem
I got one for my Lotus after no trolley jack I had would fit with a lot of sodding about, even a halfords one that I removed the front wheels and dismantled as much as possible wouldn\'t fit and was very dodgy!
This will fit under pretty much anything, has a nice rubber pad to protect what it\'s lifting and if you can\'t get it under I have no idea how you run the car on the road ;)
HTH,
Mark
Mave
Quote from: DonatoThe reason you dont get oil pouring out of it is because the oil filter is on top of the engine facing down the way, and the oil is at the bottom of the engine due to gravity  ;)
Does that mean there\'s no one-way valve on the filter? If not, does this mean that the engine is being starved on every start-up, until the filter is filled?  :xconfused  Makes a good case for relocating the filter to be the right way up!
